Configures the LLDP port to advertise or not advertise up to 4 file server IP addresses to its neighbors. The Avaya phone uses this proprietary LLDP TLV to learn the IP address(es) of the file server(s) to use.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| advertise | Specifies to send the information to neighbors. |
| no-advertise | Specifies not to send the information to neighbors. |
| ip_address_1...4 | Specifies IP address of up to
4 file servers. NOTE: This parameter does not apply when you configure the no-advertise parameter. |
No advertise.
The Avaya phone uses this proprietary LLDP TLV for addressing information. You can configure the IP address for up to 4 file servers in a single TLV.
The following command configures all ports to advertise two file server IP addresses to neighbors:
configure lldp ports 1-5 advertise vendor-specific avaya-extreme call-server 10.20.10.10 10.12.10.10
This command was first available in ExtremeXOS 11.5.
